Tools
Dameware Remote Everywhere Tech Console Taskbar Icon
Steps for creating a DRE Tech Console icon on the Windows taskbar
- How can we create an MSP Anywhere Tech Console icon on the Windows Taskbar?
- If you wish to create an MSP Anywhere Tech Console icon on your Windows Taskbar, you should:
- Right click on the icon SolarWinds N-able MSP Anywhere present on your Desktop
- Select Pin to Taskbar
- You can also:
- Go to C:\Users\<User Name>\AppData\Local\BeAnywhere Support Express\Console
- Right-click on BAConsoleApp.exe
