Tools
Dameware Remote Everywhere (DRE) logs, files, and diagnostics locations for troubleshooting
This article show where to get DRE logs, files, and diagnostics locations when troubleshooting DRE issues.
Windows
DRE Applet (Remote end)
Windows 8 or later:
- %LOCALAPPDATA%\Dameware Remote Everywhere Applet\Logs
DRE Agent (Remote end)
Windows 8 or later:
- C:\ProgramData\GetSupportService_Dameware\logs
- C:\ProgramData\GetSupportService_Common_Dameware\logs
Agent Installer (Remote end)
- C:\Windows\Temp\ServerApplet\ServiceInstaller.install.log
DRE Technician console (Technician's end)
Windows 8 or later:
- %LOCALAPPDATA%\Dameware Remote Everywhere\Logs
End-User Viewer (Client's end)
- %LOCALAPPDATA%\Dameware Remote Everywhere\Viewer\Logs
macOS
DRE Technician console (Technician's end):
- /Users/<user>/Library/Logs/DamewareRemoteEverywhere/Console
- /Users/<user>/Library/Logs/DamewareRemoteEverywhere/Viewer
- Logs can also be found in the DRE console application > Gear icon > Show log folder (Library sometimes also hidden)
DRE Agent
- /Users/{user}/Library/Logs/Take Control Agent dameware
- Or /Users/{user}/Library/Logs/Take Control Agent dameware
Applet (Remote end):
- /Users/<user>/Library/Logs/MSP Anywhere/Applet
Agent Installer (Remote end):
- /Library/Logs/MSP Anywhere Installer
End User Viewer (Technician's end):
- Users/<user>/Library/Logs/MSP Anywhere/Viewer MSPA Standalone
IOS logs
- iOS applet logs should be located in the user's Library folder
DRE Proxy
- C:\ProgramData\BeAnywhere\BASupProxy\Logs
