Tools
Dameware Remote Everywhere: Creating a Post-Session Survey - Video
In this quick video (00:50), you'll learn how to create a post-session survey in Dameware Remote Everywhere.
In this quick video (00:50), learn how to create a post-session survey in Dameware Remote Everywhere.
Dameware Remote Everywhere is a fast, simple, and lightweight cloud-based remote support solution, accessible from almost anywhere with an internet connection.
Video Transcript
To create a post-session survey, click on 'Management,' and then 'Surveys.'Click the 'Add' button and enter a name and description.
To add a question to the survey, select it from the column on the left, and click the 'Add' button at the bottom of the page.
You can create your question based on four different answer types.
Once you've created a series of questions, you can easily rearrange their order.
