Tools
Dameware Mini Remote Control installation error
In some cases, Dameware Mini Remote Control version 12 and later versions do not install correctly, or you may encounter an error. As a workaround, you can install Dameware Remote Support, which contains Mini Remote Control. Even though you only have a license for Mini Remote Control, the installation still completes. During the installation, make sure to enter the Mini Remote Control license key into the Dameware Licensor dialog box.
Note: If you receive a .NET error, then upgrade to 4.5 .NET framework, or activate Dameware offline.
Important links:
Dameware Remote Support installer:
The installer is located in the Customer Portal (v12.x)
Offline Activation: Dameware license offline activation
