Tools
Dameware Mini Remote Control – Smart Card Logon Fails With “Username Not in Correct Format” After Fresh Standalone Install
On a fresh standalone Dameware Mini Remote Control 12.3.2 installation, Smart Card Logon to Windows hosts fails with a “username not in correct format” message.
Fresh standalone Dameware MRC 12.3.2 install on technician PC.
Smart Card Logon is selected in Remote Connect → Authentication method.
Flow:
Technician enters hostname of remote Windows machine.
Chooses Smart Card Logon.
Enters PIN.
Selects the appropriate Smart Card certificate.
Username auto‑populates (or remains blank if relying on default cert mapping).
Windows returns:
“The username you entered is not the correct format, please enter the correct format or specify the domain in the domain field.”
Native Windows / RDP smart‑card logon to the same host with the same card + PIN works.
Issue is seen across multiple hosts (not tied to a single machine).
Although the environment meets the general Smart Card requirements (OS support, Smart Card Service, AD/PKI configuration, and working RDP Smart Card logon), the initial Dameware installation on the technician machine was not fully completed with elevated administrator rights.
Because of this, one or more Dameware Smart Card–related components (driver, virtual reader, or associated cryptographic modules/registry keys) were not correctly registered. When Dameware attempted Smart Card Logon, Windows received an incomplete or invalid identity mapping from the Dameware Smart Card provider, and responded with the generic username/domain format error even when the Username field was correct or auto‑populated.
Once Dameware was re‑run with elevated permissions (via the License Manager), the installer was effectively re‑applied with full admin rights, which properly registered the Smart Card components. After that, the same Smart Card workflow (card → PIN → certificate) succeeded without further changes.
Exact Fix
One‑sentence fix:
Rerunning Dameware (installing/launching the License Manager) with elevated administrator credentials completes the installation and properly registers the Smart Card components, enabling Smart Card Logon to work.
Detail:
On the technician PC:
Launch/install the Dameware License Manager using an elevated admin account (Run as administrator).
This elevated run causes the Dameware installer/licensing process to:
Re‑apply Dameware with full admin rights.
Fully register the required Smart Card provider/driver and supporting binaries under HKLM and the correct program files path.
Without changing host configuration or cards:
Open Dameware MRC.
Select Smart Card Logon.
Insert card → enter PIN → select certificate.
The username auto‑populates and Smart Card Logon succeeds; the previous username‑format error does not reappear.
Recommended Remediation / Preventive Steps
1. Install Dameware Standalone with Full Admin Rights
For fresh standalone deployments:
Download and install Dameware Mini Remote Control (64‑bit or 32‑bit standalone) from the Customer Portal (see 12.3 release notes installer list).
Always run:
The installer, and
The initial License Manager / activation
as a local administrator (right‑click → Run as administrator).
This ensures all Dameware binaries, Smart Card components, and registry keys are written correctly.
2. Confirm Smart Card Requirements on the Remote Host(s)
Per About Smart Card requirements for Dameware:
Remote OS must be Windows 7 or later.
Smart Card Service (scardsvr) must be installed and running.
Smart Card and PIN must have rights to log on to the remote machine.
AD/PKI must be correctly configured:
AD trusts the issuing CA.
Workstations and DCs have valid certificates for Smart Card auth.
A Smart Card reader is required on the local machine, not on the remote.
Verify that native Windows / RDP smart‑card logon works before troubleshooting Dameware.
3. (Optional but Recommended) Build Agent with Explicit Smart Card Support
If you deploy custom agents via MSI Builder:
Open Mini Remote Control Client Agent MSI Builder.
In Package Builder:
Set Target O/S correctly.
Enable “Install the smart card driver”.
In Client Agent Settings ensure Allow Smart Card Logon is checked.
Click Build MSI and deploy that agent to remote hosts.
