Tools
Dameware Mini Remote Control (DMRC) Send menu options is grayed out running on Citrix
The MRC Send menu options are grayed out after the upgrade to 12.3.0.
- Citrix environment
- The user is connecting to a jump box server to launch the DMRC
- DMRC user is not an admin to the jump box where DMRC was installed
- They are only admins to the remote computers
- Only some DMRC users are affected
- Dameware MRC version is 12.3.0
