Tools
Dameware Exporter - Error 53 - The network path was not found
What to do if you receive a System Error 53 - The network path was not found error displays in both the Last Error column in the Computer List pane and the Information pane specific machines in the network when running Dameware Exporter.
- In the target affected machine, go to services.msc and locate the Remote Registry Service.
- Enable the service and set to Automatic.
- Alternatively, you can use Dameware Remote Support (DRS) to do a batch enable and set to Automatic for all machines in the network.
See also: Error 53: Network path was not found in Dameware Remote Support
