Tools
DRE Enduser on macOS cannot connect to remote devices
Resolve error with endusers on macOS that states "PC is not Ready to Receive TCP Connections"
- Mac clients suddenly cannot connect to remote devices with agent v.6.80.20 through DRE enduser viewer
- Error: "PC is not ready to receive TCP connections"
- Go to the enduser area
- Insert the enduser credentials
- Click the button Install extension
- Run the installer
