Applications Systems
DPM installation token is invalid
During the installation of the DPM agent, the installation script indicates that the token is invalid.
After downloading and attempting to run the installation script to install the DPM agent a user may receive an error similar to the following:
The API token you used, ABCDEFGHI123456789, is not valid, please verify and retry installation.
This is usually caused by one of the following:
- The token has expired.
- The token is not an installation token but a token created using the API Tokens page.
Tokens used for installation are only provided by the Add New Host wizard; tokens created on the API Tokens page within Settings are used for integration with Single Sign On and the DPM API.
