Database Management
DPAIM installation options
DPAIM is automatically installed when you install any product that runs on the SolarWinds Platform.
11/1/2018 3:48 PM
2/20/2025 12:30 AM
DPAIM is automatically installed in any SolarWinds Platform deployment.
Database Performance Analyzer
If you have an existing SolarWinds Platform deployment, DPAIM is installed with other platform modules. To begin using it, set up the DPA Integration Module.
For more information, see the DPAIM integration overview.
