Applications Systems
DPA website is not accessible after an upgrade to 2025.2 and displays an error "ERR_CONNECTION_REFUSED"
This article explains the recent changes in the server.xml file that made the DPA web console unaccessible after upgrading to 2025.2.
If you are upgrading from DPA 2024.4.200 or earlier to DPA 2025.2 and added or changed any of the additional properties within the server.xml file, you need to manually configure those properties. One Windows the DPA installer will create a backup of the server.xml in the format appended with date, for example: server-20250513-083327-backup.
Manually update the new server.xml file at C:\Program Files\SolarWinds\DPA\iwc\tomcat\conf\server.xml. Map the old properties to the new properties as shown in the table below.
You will see errors something like these in the Catalina<date>.log. {DPA Dir}DPA\iwc\tomcat\logs
06-Jun-025 08:59:19.684 INFO [main] com.confio.ignite.keys.certificates.CertificateConfigurationTask.getHostName Host name resolved to [SubjectNames{commonName='<FQDN>', hostNames=[ServerName/HostName], ips=[IP_Address, 0:0:0:0:0:0:0:1]}]
06-Jun-2025 08:59:19.689 INFO [main] com.confio.ignite.keys.certificates.CertificateConfigurationTask.run Interrogating keystore file [D:\Program Files\SolarWinds\DPA\iwc\tomcat\conf\.keystore]
06-Jun-2025 08:59:20.034 INFO [main] com.confio.ignite.keys.certificates.CertificateConfigurationTask.run Alias name not specified.
06-Jun-2025 08:59:20.034 INFO [main] com.confio.ignite.keys.certificates.CertificateConfigurationTask.run Key entry exists in keystore.
06-Jun-2025 08:59:20.039 INFO [main] com.confio.ignite.keys.certificates.CertificateConfigurationTask.handleCertificate Certificate in keystore under alias [tomcat] is not self-signed or DN does not match the template DN. No action.
06-Jun-2025 08:59:20.084 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8123"]
06-Jun-2025 08:59:20.174 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["https-jsse-nio-8124"]
06-Jun-2025 08:59:20.724 SEVERE [main] org.apache.catalina.util.LifecycleBase.handleSubClassException Failed to initialize component [Connector["https-jsse-nio-8124"]]
org.apache.catalina.LifecycleException: Protocol handler initialization failed
at org.apache.catalina.connector.Connector.initInternal(Connector.java:1051)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:122)
at org.apache.catalina.core.StandardService.initInternal(StandardService.java:522)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:957)
at org.apache.catalina.startup.Catalina.load(Catalina.java:712)
at org.apache.catalina.startup.Catalina.load(Catalina.java:735)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:569)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:302)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:475)
Caused by: java.lang.IllegalArgumentException: Get Key failed: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at org.apache.tomcat.util.net.AbstractJsseEndpoint.createSSLContext(AbstractJsseEndpoint.java:114)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.initialiseSsl(AbstractJsseEndpoint.java:70)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:200)
at org.apache.tomcat.util.net.AbstractEndpoint.bindWithCleanup(AbstractEndpoint.java:1304)
at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:1317)
at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:633)
at org.apache.coyote.http11.AbstractHttp11Protocol.init(AbstractHttp11Protocol.java:82)
at org.apache.catalina.connector.Connector.initInternal(Connector.java:1049)
... 13 more
Caused by: java.security.UnrecoverableKeyException: Get Key failed: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at java.base/sun.security.pkcs12.PKCS12KeyStore.engineGetKey(PKCS12KeyStore.java:450)
at java.base/sun.security.util.KeyStoreDelegator.engineGetKey(KeyStoreDelegator.java:91)
at java.base/java.security.KeyStore.getKey(KeyStore.java:1050)
at org.apache.tomcat.util.net.SSLUtilBase.getKeyManagers(SSLUtilBase.java:393)
at org.apache.tomcat.util.net.SSLUtilBase.createSSLContext(SSLUtilBase.java:268)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.createSSLContext(AbstractJsseEndpoint.java:112)
... 20 more
Caused by: javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at java.base/com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:862)
at java.base/com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:942)
at java.base/com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:735)
at java.base/com.sun.crypto.provider.PBES2Core.engineDoFinal(PBES2Core.java:325)
at java.base/javax.crypto.Cipher.doFinal(Cipher.java:2205)
at java.base/sun.security.pkcs12.PKCS12KeyStore.lambda$engineGetKey$0(PKCS12KeyStore.java:371)
at java.base/sun.security.pkcs12.PKCS12KeyStore$RetryWithZero.run(PKCS12KeyStore.java:257)
at java.base/sun.security.pkcs12.PKCS12KeyStore.engineGetKey(PKCS12KeyStore.java:361)
10-Aug-2025 04:36:01.618 SEVERE [main] org.apache.catalina.util.LifecycleBase.handleSubClassException Failed to initialize component [Connector["https-jsse-nio-8124"]]
Caused by: java.lang.IllegalArgumentException: No SSLHostConfig element was found with the hostName [_default_] to match the defaultSSLHostConfigName for the connector [https-jsse-nio-8124]
| Old Property | New Property | Formatting example |
keystoreType="PKCS12" | certificateKeystoreType="PKCS12" |
The updated format should look like the example below.
keystorePass="password" | certificateKeystorePassword="password" |
The updated format should look like the example below. <SSLHostConfig hostName="dpasslhost"><Certificate certificateKeystoreFile="conf/.keystore"certificateKeystoreType="PKCS12"certificateKeyAlias="somealias"certificateKeystorePassword="password"certificateKeyPassword="keypassword"type="RSA" /></SSLHostConfig> |
keyPass="keypassword" | certificateKeyPassword="keypassword" |
keyAlias="somealias" | certificateKeyAlias="somealias" |
Full article details:
https://documentation.solarwinds.com/en/success_center/dpa/content/dpa-upgrade-dpa-on-windows.htm
For customers running DPA on Linux:
Backup server.xml before moving to Step 6 as per Upgrade DPA on a Linux-based OS
Then do step 7 (copy old confs to new etc.)
Restore new server.xml
Edit Server.xml to replace
hostName="dpasslhost" and defaultSSLHostConfigName="dpasslhost" withthe dpa server hostname and any other changes you made earlier in your old server.xml file -
Start DPA service.
