Applications Systems
DPA error: The IDC is not currently running, so no data is being collected
The following error occurs when accessing DPA installed on a Windows OS: The IDC is not currently running, so no data is being collected.
Applicable to All DPA versions running on Windows
- The error is caused when the DPA heap memory or the DPA service is in an invalid state.
- Another reason is DPA repository DB is in read-only state
- Increase DPA heap memory to monitor large numbers of instances If this does not resolve the issue, proceed to Step 2.
- Restart the DPA service:
- Click Start > Control Panel > Administrative Tools > Services.
- Search for Ignite PI Server service.
- Right-click, and then select Stop/Start. If restarting the service does not resolve the issue, log a Support ticket and Send log files to SolarWinds Support to SolarWinds support.
1. Work with your DBA to make the repository DB in read-write
2. Restart the IDC service
