Applications Systems
DPA buttons do not work
If javascript is disabled in Internet Explorer, buttons in DPA will not be active due to Enhanced Security Configurations.
If possible do one of the following:
- Access DPA on a client computer, and not the DPA server.
- Use another browser such as Chrome or Firefox.
- Check if JavaScript is disabled in the browser settings.
If the above solutions are not feasible, identify the computer running the DPA server as a local site. Follow these steps to enable scripting, assuming that the local intranet was not further locked down by the system administrator:
- In Internet Explorer, click Tools > Internet options.
- Click the Security tab, and click Local Intranet.
- Click Sites.
- Click Advanced.
- Add the following website: http://yourservername:8123
- Click Add, and Close.
If the local intranet was locked down by the system administrator, follow these steps to enable scripting for all web sites:
- Click Custom level.
- Under Scripting > Active Scripting, click Enable, and then click OK.
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
