DHCP managed subnet not showing information in IPAM
This article will show you how to troubleshoot DHCP servers issues, such as missing endpoint devices.
Symptoms: IP addresses do not show the endpoint information such as Hostname and MAC address
If you edit the subnet it is not showing that it is associated in any DHCP server
- Go to My Dashboards > IP Addresses > DHCP & DNS Management.
- Click DHCP Servers (or DHCP if using the legacy dashboard) if not already selected.
- Select the DHCP server to be removed.
- Click My Dashboards > IP Address Manager > Manage Subnets & IP Addresses.
- Select the Subnet to be removed
- Delete the subnet
- Click Settings > All Settings > IPAM Settings > Add DHCP server.
- Select the server from the Choose DHCP Server drop-down menu. You can group servers by a variety of methods to make finding the required server easier.
- Select a credential type, and either select the credential name to be used, or create a new credential.
- Click Test to verify the credential on the selected server.
- Click Add DHCP server
