Tools
Customize the subject line for Web Help Desk emails
This article describes how to customize email Subject line(s) used by Web Help Desk.
You may be able to customize the email Subject line(s) used by Web Help Desk by following the steps described on this article.
Microsoft Windows and Mac OS X:
- Stop Web Help desk (Stop and start Web Help Desk).
- Open the Web Help Desk home directory.
Apple® OS X:/Library/WebHelpDesk
Windows:\Program Files\WebHelpDesk - Navigate to
/conf/labels. - Backup or duplicate the
Labels.propertiesfile and rename the duplicate fileCustomLabels.properties. - Open the
CustomLabels.propertiesfile in Notepad or any text editing application - Scroll down to E-Mail Subjects and select the template you want to edit.
- Save and close the file.
- Start web Help Desk (Stop and start Web Help Desk).
Linux or Virtual Appliance deployment
- Open PuTTY.
- SSH to the Virtual Appliance or Linux box as an admin.
- Change to the user root.
sudo su - - Stop Web Help Desk.
service webhelpdesk stop - Open the Web Help Desk directory at:
/usr/local/webhelpdesk - Navigate to
/conf/labels. - Copy the labels.properties file and rename the new file
CustomLabel.properties.cp/usr/local/webhelpdesk/conf/labels/Labels.properties/usr/local/webhelpdesk/conf/labels/CustomLabels.properties
- Open the CustomLabels.properties file.
vi /usr/local/webhelpdesk/conf/labels/CustomLabels.properties
- Search for the E-Mail Subjects portion of the file.
/E-Mail Subjects - Select the template that you want to edit.
To edit the file, press
Aand then replace the test or enter the information you want to add to the file. - Press <Esc> + <Shift> + <Z> + <Z> to exit the editor and save the file.
- Start Web Help Desk.
service webhelpdesk start
