Tools
Customize the Web Help Desk GUI language and labels
This article describes how to customize the WHD GUI language and labels.
You can change the labels in the Web Help Desk GUI by following the steps on this article. This is helpful especially if you want the labels to appear on your own language.
- Navigate to your Web Help Desk home directory.
Apple® macOS®:/Library/WebHelpDesk
Microsoft® Windows®:\Program Files\WebHelpDesk
Linux:/usr/local/webhelpdesk - Navigate to
/conf/labelsand open theLabels.propertiesfile in a text editor (such as Notepad++).This is the default labels file that contains all default labels used by the application. Do not edit this file. View the contents and locate the labels you need to change.
- In the
/labelsdirectory, create a custom labels file namedCustomLabels.properties.txt.This file will only include the labels you need to change. The application will use the default labels for any value not found in the
CustomLabels.propertiesfile. - Copy the label entries you need to change from the
Labels.propertiesfile to theCustomLabels.properties.txtfile.
For example, to change the label forTicketto readJob, enterlbl.ticket=Jobin theCustomLabels.properties.txtfile.If you cannot find the label in the
Labels.propertiesfile, you cannot modify the label. - Rename the
CustomLabels.properties.txtfile toCustomLabels.properties, removing the.txtextension.
Supporting additional languages
You can create additional CustomLabels.properties files for specific locales by prefixing .properties with a language and country code as specified by ISO 639 and 3166. For example, to define custom labels for Spanish clients, create a file named CustomLables_es.properties in the /labels directory and add your custom label definitions.
To define label specifically for Mexican Spanish, name the file CustomLabels_es_MX.properties.
Web Help Desk queries the files starting with the most specific match. For example, if a Spain client submits a request, the application will access the following files in order until it can define the label:
CustomLabels_es_ES.propertiesCustomLabels_es.propertiesCustomLabels.propertiesLabels.properties
For complete listings of ISO 369 and 3166 language and country codes, see:
- ISO 369-1 and 369-2 Language Codes (© 2017 International Organization for Standardization, available at http://www.iso.org, obtained on November 11, 2017)
- ISO 3166 Country Codes (© 2017 Library of Congress, available at http://www.loc.gov, obtained on November 11, 2017)
Oracle Java requires properties files to be in Latin-1 or escaped Unicode format, where Unicode characters are represented by Unicode escape sequences. You can use the native2ascii Java tool to convert native-encoded files to to this format. This tool is located at <WebHelpDesk>/bin/native2ascii. Additionally, UTF-8 encoding does not use Unicode escape sequences. Use the native2ascii tool convert UTF-8 encoded files.
Java tool syntax
The native2ascii tool uses the following syntax:
native2ascii -encoding "<encoding_name>" [input_file] [output_file]</encoding_name
For example, to convert a file encoded in Shift-JIS to escaped Unicode, execute the following command:
native2ascii -encoding "SJIS" CustomLabels_ja.properties.orig CustomLabels_ja.properties
See native2ascii - Native-to-ASCI Converter ascii on the Oracle website for a list of supported encoding and instructions on using the native2ascii tool. (© 2017 Oracle Corporation, available at http://www.oracle.com, obtained on November 11, 2017)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
