Tools
Custom script fields in Kiwi Syslog
This article describes custom script fields in Kiwi Syslog
By writing a parsing script, the syslog message text can be broken down into various sub fields. The values can then be assigned to the 16 custom fields and then logged to a database or flat file.
Because each device manufacturer creates syslog messages in a different format, it is not possible to create a generic parser that will break up the message text into separate fields. A specific customized message parsing script must be written to parse the message text, and then place it in the custom fields.
A tutorial on creating parsing scripts can be found at: http://www.kiwisyslog.com/help/syslog/tutorial_creating_script.htm
Some example parsing scripts are included with the Kiwi Syslog install. These can be found in the Scripts sub folder, which is usually by default: C:\Program Files (x86)\Syslogd\Scripts
