Custom thresholds do not reflect their status color in the web console
This article discusses about a behavior in the SolarWinds Platform where custom thresholds applied to objects do not reflect accurately in the color of their status in the web console.
10/29/2018 3:08 PM
7/23/2025 9:53 PM
When applying custom thresholds in the web console, you may notice that their object color(critical/warning) would not reflect accurately on these thresholds. For example:
Set a custom threshold for a volume. Warning > 70, critical >85
A Physical Memory on 94% should've shown as red(critical)
Go to Settings > All Settings > Platform Thresholds and adjust levels(e.g. Warning > 70, critical > 85
A Physical Memory on 94% would now show red as expected
Network Performance Monitor
Unknown
Please contact support for investigation.
