Tools
Custom filter is not accessible on Kiwi Syslog Web Access
When you try to add a filter in Kiwi syslog web access and you select the filter type, you will see two options: standard filter and custom filter. Custom filter could not be selected.
10/18/2018 8:21 PM
10/18/2018 8:21 PM
The custom filter option cannot be selected when attempting to add a filter in Kiwi Syslog Web Access and selecting a filter type.
Kiwi Syslog Server
The current version of Kiwi Syslog Web Access supports only standard filter types. Future releases may include other filter types.
Use standard filter type only.
