Create a Custom bandwidth interface receive / transmit utilization alert in NPM
You have custom bandwidth setup on the interface and wanted to get get alerted certain utilization on specific Transmit / Receive numbers
If you have NPM 12 or earlier installed, use this link Create an alert for Interface Utilization over 50%
Configure the Transmit and Received alert and set the value manually assuming that you have 95% utilization from your ISP provider.
You can go more specific:
Select > Interface > Current Traffic > Xmit bps Recv bps
Use the following variables under Alert Actions Email:
Alert Variables:
Node IP Address: ${Node.IP_Address}
Node Name: ${NodeName}
Interface Name: ${FullName}
Inbps (Receive) Traffic: ${Inbps as Bandwidth}
Outbps (xmit) Traffic: ${Outbps as Bandwidth}
In bps as Bytes: ${Inbps as Bytes}
Out bps as Bytes: ${Outbps as Bytes}
In bps: ${Inbps}
Out bps: ${Outbps}
If you have NPM 12.2 or above installed please find the Options below
Other options available based on Gbps utilizaiton
