Custom Report: Hourly average CPU and memory usage
This article will show how to create a custom report that shows an hourly break down of average CPU and Memory usage over a 24 hour period.
- Log in to the Orion Web Console.
- Click Settings > All Settings.
- Under Alerts and Reports, click Manage Reports.
- Click Create New Report.
- Complete the report wizard.
- Select Custom Table and click Select and Continue.
- Set the Data Selection as follows, and click Add to layout:
- For Selection method use - Specific Objects
- Select the nodes for the report.
- To set up the Custom table, click Add Column and add the following:
- Node Name
- Average CPU Load
- Average Memory Used
- Set the Time-based settings Sample Interval to Hour.
- Set the Sort and Group Results By to - Node.
- Set the From option to Last 24 hours.
- Finish the report wizard.
