Tools
Create and deploy scripts in Dameware Remote Everywhere (DRE)
This article shows how to deploy the different types of scripts with DRE
The script can be explicitly entered in DRE or call it from a different location such as cloud storage.
Supported script type:
- Powershell (*.ps1)
- Batch (*.bat)
- Visual Basic (*.vbs)
Notes: When calling the script from a different location, the file should be auto-download, otherwise it will not run.
- Login to your Admin Area.
- Navigate to Management > Scripts.
- Click the Add button (top right corner after "Scripts").
- Fill in the script name and description.
- Click Add.
- Select the newly created script from the list.
- On the chart below the script list, enable the script and Save changes.
- Select the CONTENT tab, fill out the script body/type and Save changes.
- Select the REQUIRED FILES tab and add the desired files by clicking the button Add new.
- Login to your Admin Area .
- Navigate to Devices.
- Select the device on which you want to deploy the script.
- Click the button Deploy Script.
- Set the Job name and select the script
- Choose other preferred running options if desired.
- Click Deploy.
