Create an iControl account for F5 monitoring in NPM
Details and requirements of iControl account used to monitor F5 BIG-IP devices.
NPM uses iControl to poll health monitors for Network Insight for F5 BIG-IP load balancers. You can use the default F5 Administrator account for this monitoring. If that is not an option, create a new iControl account.
The iControl account you are using in NPM must be a local account directly on the F5 device. You cannot use Active Directory or TACACS accounts.
- Log in to your F5 device and navigate to System > Users > User list > New user.
- In the Role drop-down, select Administrator.
- Finish creating the user.
For more information about user rights:
- Read the section "About iControl and RBAC for user accounts" in the User Guide for the iControl rest interface (© 2018 F5 Networks, Inc., available at https://clouddocs.f5.com/, obtained on December 5, 2019)
- Search for "iControl permissions" at https://devcentral.f5.com (© 2013 VMware, Inc., available at http://www.vmware.com/, obtained on May 4, 2016)
