Create an advanced SQL report to check nodes that fail SNMP\WMI polling
How to create a report that lists nodes that fail SNMP or WMI polling.
11/29/2018 11:00 PM
2/25/2025 6:03 PM
This article describes the SQL syntax to create a report that lists nodes that fail SNMP or WMI polling.
Network Performance Monitor
  1. From the SolarWinds Web Console, Go to Reports > All Reports. Click on Manage Reports.
  2. Click on create new Report.
  3. Select Custom Table
  4. Select method as "Advanced Database Query (SQL,SWQL)"  as the Selection Method
  5. Choose SQL as the query type
  6. Paste the query below and run preview.
  7. The following advanced SQL report checks the last 5 polls where snmp\wmi communication has been lost
SELECT Nodes.NodeID AS NetObject, Nodes.Caption AS Name
FROM Nodes
Where LastSystemUpTimePollUtc < DATEADD( second, -5*PollInterval, GETUTCDATE()) AND status =1 AND ObjectSubType IN ('SNMP', 'WMI')
  •  The Preview option helps to see the results. Also the report can be saved for later use.
