How to create an account limitation using dynamic groups in Orion
This article is created to serve as a guide on how to create an account limitation using dynamic groups in Orion
- Create a custom property to base the limitation on.
- Go to Settings > Manage Groups.
- Select + to add a new group.
- Give the Group a relevant name.
- In the Add Orion Objects, click on + Add Dynamic query.
- Give the query a name and select Node in the drop down and click on Add condition.
- Select the custom property in the drop down and the conditions and then Preview to confirm the selection and save to confirm.
- Now all nodes with this matching custom property will be dynamically added to the group.
