Create a report for the top 5 endpoints by interface in the Solarwinds Platform
This article explains how to create a report for Top 5 Endpoints by interface.
How to create a report for Top 5 Endpoints by interface.
- On the Web Console, go to Manage Reports.
- Create a new report.
- Select Custom Table.
- Set the following:
- Selection Method: Dynamic Query Builder
- Advanced Selector
- I want to report on: Netflow Flow By Hostname History
- Where: All child conditions must be satisfied (AND)
- Ingress InterfaceID is equal to 33
- Under Add Column, locate Ingress InterfaceID.
- Click Add to layout.
- Add the following columns:
- Ingress Bytes
- Hostname
- Click Add Column.
- Under the Ingress InterfaceID column Advanced options, select Hide this column in the resulting table.
- Under the Ingress Bytes column Advanced options, set the appropriate values.
- Under Filter number of results, set the Show only the top field to 5 records.
- In the Sort results by field, select Ingress Bytes - Netflow Flow By Hostname History.
- Click Submit.
- After filling out all the details for your report, click Next. A report preview will be displayed.
- Click Next and add to favorites.
- Add a schedule if needed and then Click Next.
- Review and verify the summary and click Submit.
