Create a filter for active in the SolarWinds Platform
You can create a filter for specific active alerts to be displayed in the All Active Alerts resource of the SolarWinds Platform Web Console.
- On the SolarWinds Platform Web Console, go to Alerts view.
- On the All Active Alerts resource, hover to any header of a column you want to filter.
Option 1: You can click the Filter button
at the left of the header then Enter the Filter Text.
Option 2: You can also click the Drop-down arrow
at the right of the header, then select Filters then Enter the Filter Text. This is a text based search similar to the "find" function.
3. Click Enter to apply the filter.
