Create a Live Weather Resource in Orion Web Console/Orion Maps.
This article provides steps to allow customers to add a Live Weather Map in the Orion Web Console/Orion Maps.
11/15/2018 8:42 PM
1/13/2022 2:15 PM
We have a custom HTML link under page settings, or Widgets that customers can use to display certain third-party websites like Live Weather Map in the Orion Web Console/Orion Maps.
Note - if a third-party website .gif does not work, the HTML link will fail.
Orion Platform
1.  Open the Orion Web Console.
2. From the Specific View that you want to add the Live Weather Resource click Customize Page > Add Custom HTML > Done.
3. Click Edit for the Custom HTML > Paste the following:
<IMG ALT="Live Weather" SCR="pastelinkhere" BORDER="0"> </A>
Note: To add the site copy the link of the Live Weather map and place it in the SCR="pastelinkhere"
Sample:
<IMG ALT="Live Weather" SRC="http://radar.weather.gov/Conus/Loop/NatLoop_Small.gif" BORDER="0"> </A>
Reference:
https://thwack.solarwinds.com/docs/D...72700#start=50
Please note that Thwack is a community space where users may post any content as a suggestion or recommendations to you for your internal use. The information set forth herein may come from third-party websites or customers. SolarWinds is not liable for any downtime or any issue that may occur if you perform the following suggestions on the link provided. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.
