Create a Custom Node Availability Web-Based Report in the SolarWinds Platform
This article is about creating custom Node Availability report using Web-Based Report in the SolarWinds Platform Web Console.
You can create your custom Node Availability Web-Based report from the out of the box report in the SolarWinds Platform Web Console.
Below are the steps to create your custom Node Availability Web-Based report by duplicating and modifying the out of the box report in the SolarWinds Platform:
1. Login to the SolarWinds Platform Web Console using an admin account or an account with Report Management Rights and No Limitation for Report Limitation Category
2. From the Web Console, go to Settings > All Settings > Manage Reports
3. Use the keyword “availability” on the search field
4. On the result, select the “Availability - This Year” > click DUPLICATE & EDIT and then you can begin customizing the report
You can check Create custom table report in the web console for more information.
