Tools
Copy files from Target Remote Machine to DMRC Client in DMRC using SFT
This documentation article describes the process in copying file from target remote machine to client machine using the SFT in Dameware Mini Remote Control.
However, there are instances in which the customer need to copy file from the target remote machine to client machine using the SFT in Dameware Mini Remote Control.
- Start Remote Session
- Configure Download Folder first:
- Click SFT from the DMRC Menu (Make sure windows is not maximize for the machine to appear)
- Select Open Remote Drop Window
- Drag and Drop files you need to copy inside the Remote Drop Window
- Check Upload Folder once copy was completed
