Tools
Console showing wrong language in DRE
Learn how to change the language settings for DRE
4/10/2019 9:18 PM
4/10/2019 9:18 PM
  • How do I change the language settings for the tech console?
  • The console's text is in another language, how can we change it?
Dameware Remote Everywhere
This setting can only be changed on the login screen of the console application:
  1. Logout of the Console (if already logged in) using the Log Off icon near the top right corner of the window;
  2. On the login screen, set the Language field to the intended language;
  3. You should now be able to login to the Console once again with the selected language.
