Connectivity issues, discarding configuration (or configuration is too short) error in NCM
Error when downloading startup/running config in NCM webconsole: Connectivity issues, discarding configuration (or configuration is too short)
The configuration is too short. In most (if not all) cases the output is not a valid config but rather an error message (or set of messages) provided by the device.
RESOLUTION 1:
Navigate to Settings > NCM Settings > Config Settings > Config Minimum Length.
- Change the value from 11 (default) to 1.
- Click Submit.
RESOLUTION 2:
If the issue still occurs:
- Log in to the affected device via CLI using the same account you used to log in via NCM server under Edit Node.
- Disable the Paging on the affected device via CLI by typing the following command:
terminal length 0
Note: The command for your device type might be different. Enter the command appropriate for your device. - Try to download the device config again via the NCM web console.
