Connection refused error when downloading SilverPeak device configuration
Use the provided device template in order to download config on your Silverpeak device.
<Configuration-Management Device="Silver Peak VX5000" SystemOID="1.3.6.1.4.1.23867">
<Commands>
<Command Name="ALLOCATEPTY" Value="True" />
<Command Name="Menubased" Value="False" />
<Command Name="Reset" Value="no cli session paging enable"/>
<Command Name="DownloadConfig" Value="show running-config"/>
<Command Name="Version" Value=""/>
<Command Name="Running" Value=""/>
<Command Name="Startup" Value=""/>
</Commands>
</Configuration-Management>
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
