Tools
Connect to Serv-U SFTP using the Powershell command
How to connect to Serv-U using SFTP via Powershell.
2. Run the command below.
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. sftp username@servername
3. If there is an SSH Fingerprint prompt, just type "Yes" to accept it.
4. Enter the account password.
