Security Compliance
Configure synchronization settings and populate catalogs
This article describes how to configure synchronization settings and how to populate catalogs.
The Content Team uploads new packages every 3-5 business days from the release. Once the package is ready, we upload it where the Synchronization can be performed. When completed, you will receive the new updates.
- In the Patch Manager menu, expand Administration and Reporting and select Software Publishing.
- In the Actions Pane, select Synchronization Settings.
- On the Synchronization tab, set your server to synchronize daily and assign a synchronization time.
- On the Subscriptions tab, select the products you want to synchronize.
- Click Synchronize, and then click OK.
