Applications Systems
Configure Performance Counter monitor fetching method order for SAM
Performance Counters can be fetched by several methods, including WinRM, Managed (RPC), WMI, External (RPC), PDH (RPC). Through the Performance Counter monitor, you can set the primary or preferred fetching method. If that method fails, you can set the preferred order of fallback methods in the SolarWinds.APM.Probes.config file.
Starting in SAM 2020.2, WinRM is the default fetching method for WMI-based component monitors. As a result, the original article in this location became outdated.
For the latest information about defining fetching methods for Performance Counter Monitors, see Choose a fetching method for Performance Counter Monitors in SAM in the SAM Template Reference.
