Security Compliance
Configure SEM to use a static IP address
This page shows you how to configure Security Event Manager (SEM) to use a static IP address. Refer to these steps if you need to change a previously configured static IP address.
- Access the CMC prompt:
- Virtual Console: Arrow down to Advanced Configuration, and then press Enter.
- SSH Client: Log in using your CMC credentials.
- In the cmc> prompt, enter
appliance. The prompt changes to cmc::acm#, indicating you are in the appliance configuration menu. - In the acm> prompt, enter
netconfig.
Note: All the network configuration information must be available with you as you go through all the prompted steps.
