Tools
Configure LDAP authentication Login ID attribute using sAMAccountName in Serv-U
An article showing details on how to configure the Login ID to use sAMAccountName.
2. Go to the Domain, select Users.
3. Click the LDAP authentication, select the LDAP server.
4. Click Show Advanced LDAP options.
5. In the search filter, set the following.
(&(objectclass=user)(sAMAccountName=$LoginID))6. Change the Login ID into sAMAccountName.
