"Invalid object name 'dbm_TimeSeriesConfig'" when running configuration wizard with an existing empty database for SolarWinds Platform 2023.3
The customer is getting an error on Configuration Wizard during Silent Installation. Error while executing script - Invalid object name 'dbm_TimeSeriesConfig'
10/16/2023 3:27 AM
2/19/2025 8:48 PM
-This issue occurs both on manual and silent installation
-The customer is using a pre-created empty DB
-The plan is to use an empty DB and let SolarWwinds Configuration Wizard complete it
Network Performance Monitor
This issue applies to SolarWinds Platform 2023.3.
To resolve this problem, please upgrade to SolarWinds Platform 2023.4 and above.  Unfortunately, there is no workaround for this issue.
