Applications Systems
Components that can be assigned to external nodes
This article lists components that you can use with an external node type of node in Orion as the node the application the component is on is assigned to.
10/16/2018 6:38 PM
10/16/2018 6:38 PM
This article provides a list of components that you can use with an external node type of node in Orion as the node the application the component is on is assigned to.
Server Application Monitor
You can use the following component types in an application assigned to an external node:
  • HTTP Monitor
  • HTTPS Monitor
  • HTTP Form Login
  • SSL Certificate Monitor
  • TCP Port Monitor
