Comparison of AIX agent polling versus agentless polling in Orion Platform products
The following table displays a comparison of which features are available for the AIX agent versus agentless.
To learn more about agents, see:
- Poll devices with SolarWinds Orion agents (Orion Platform Administrator Guide)
- SolarWinds Orion agent requirements (Orion Platform Administrator Guide)
- Monitor with Orion agents in SAM (SAM Administrator Guide)
- Installing the Orion Platform Agent (video)
- Mass deploy Windows agents using MST files and a Group Policy.
- SolarWinds Orion Platform products using Orion Core 2016.2 and later
AIX agent |
AIX agentless | ||
| 1 | Node Name/Caption | Yes | Yes |
| 2 | Node Status | Yes | Yes |
| 3 | Response Time/Latency (ICMP) | Yes | Yes |
| 4 | Response Time/Latency (SNMP) | No | Yes |
| 5 | Response Time/Latency (Agent) | Yes | No |
| 6 | Packet Loss | Yes | Yes |
| 7 | IP Addresses | Yes | Yes |
| 8 | IP Address Type (IPv4 or IPv6) | Yes | Yes |
| 9 | Machine Type | Yes | Yes |
| 10 | DNS Name | Yes | Yes |
| 11 | Description | Yes | Yes |
| 12 | Location | Yes | Yes |
| 13 | Contact | Yes | Yes |
| 14 | Last Boot | Yes | Yes |
| 15 | Number of CPUs | Yes | Yes |
| 16 | CPU Usage | Yes | Yes |
| 17 | Individual CPU Core Usage | Yes | Yes |
| 18 | Memory Usage | Yes | Yes |
| 19 | Total Memory | Yes | Yes |
| 20 | Vendor | Yes | Yes |
| 21 | Availability | Yes | Yes |
| 22 | Quality of Experience (QoE) | No | No |
| 23 | Universal Device Poller | No | Yes |
| 24 | Device Studio/Custom Pollers | No | Yes |
| 25 | VMware Virtualization Monitoring (Basic) | N/A | N/A |
| 26 | Hyper-V Virtualization Monitoring (Basic) | N/A | N/A |
| 27 | Hardware Health | No | No |
| 28 | Asset Inventory | No | Yes |
| 29 | Real-Time Process Explorer | Yes | No |
| 30 | PerfStack Real-Time Polling | No | Yes |
| 31 | Web Based SSH Client | Partial* | Yes |
| 32 | Network Interface Monitoring - SAM | Yes | No |
| 33 | Network Interface Monitoring - NPM | No | Yes |
| 34 | Real-Time Service Manager | No | No |
| 35 | Real-Time Event Log Viewer | No | No |
| 36 | Reboot | Yes | No |
| 37 | Routing | No | Yes |
| 38 | Topology | No | Yes |
| 39 | Linux Load Average | Yes | No |
| 40 | Volume Name | Yes | Yes |
| 41 | Volume Status | Yes | Yes |
| 42 | Volume Type | Yes | Yes |
| 43 | Volume Size | Yes | Yes |
| 44 | Volume Space Used | Yes | Yes |
| 45 | Volume Space Available | Yes | Yes |
| 46 | Volume Percent Used | Yes | Yes |
| 47 | Volume Allocation Failures | No | Yes |
| 48 | Volume Avg. Disk sec/Transfer (Latency) | No | No |
| 49 | Volume Disk queue length | Yes | No |
| 50 | Volume Read I/O | Yes | No |
| 51 | Volume Write I/O | Yes | No |
| 52 | Volume Total IOPS | Yes | No |
| 53 | AppInsight for IIS | N/A | N/A |
| 54 | AppInsight for Exchange | N/A | N/A |
| 55 | AppInsight for SQL | N/A | N/A |
| 56 | DHCP User Experience Monitor | No | Yes |
| 57 | Directory Size Monitor | Yes | Yes |
| 58 | DNS Monitor - TCP | No | Yes |
| 59 | DNS Monitor - UDP | No | Yes |
| 60 | DNS User Experience Monitor | Yes | Yes |
| 61 | Download Speed Monitor | No | Yes |
| 62 | Exchange Web Services UX Monitor | N/A | N/A |
| 63 | File Age Monitor | Yes | No |
| 64 | File Change Monitor | Yes | No |
| 65 | File Count Monitor | Yes | No |
| 66 | File Existence Monitor | Yes | No |
| 67 | File Size Monitor | Yes | No |
| 68 | FTP Monitor | No | Yes |
| 69 | FTP User Experience Monitor | No | Yes |
| 70 | HTTP Form Login Monitor | No | Yes |
| 71 | HTTP Monitor | Yes | Yes |
| 72 | HTTPS Monitor | Yes | Yes |
| 73 | IMAP4 Monitor | No | Yes |
| 74 | IMAP4 User Experience Monitor | No | Yes |
| 75 | JMX Monitor | Yes | Yes |
| 76 | LDAP User Experience Monitor | N/A | N/A |
| 77 | Linux/Unix Script Monitor | Yes | Yes |
| 78 | MAPI User Experience Monitor | N/A | N/A |
| 79 | Nagios Script Monitor | Yes | Yes |
| 80 | NNTP Monitor | No | Yes |
| 81 | ODBC User Experience Monitor | Yes | Yes |
| 82 | Oracle User Experience Monitor | No | yes |
| 83 | Performance Counter Monitor | N/A | N/A |
| 84 | POP3 Monitor | No | Yes |
| 85 | POP3 User Experience Monitor | No | Yes |
| 86 | Process Monitor | Yes | No |
| 87 | Process Monitor - Windows | N/A | N/A |
| 88 | RADIUS User Experience Monitor | No | Yes |
| 89 | Service Status - SNMP | N/A | N/A |
| 90 | SMTP Monitor | No | No |
| 91 | SNMP Monitor | Yes | Yes |
| 92 | SOAP Monitor | Yes | Yes |
| 93 | SQL Server User Experience Monitor | N/A | N/A |
| 94 | SSL Certificate Expiration Date Monitor | No | Yes |
| 95 | TACACS+ User Experience | No | Yes |
| 96 | TCP Port Monitor | Yes | Yes |
| 97 | Tomcat Server Monitor | Yes | Yes |
| 98 | VMware Performance Counter Monitor | N/A | N/A |
| 99 | Web Link Monitor | No | Yes |
| 100 | Windows Event Log Monitor | N/A | N/A |
| 101 | Windows PowerShell Monitor | N/A | N/A |
| 102 | Windows Script Monitor | N/A | N/A |
| 103 | Windows Service Monitor | N/A | N/A |
| 104 | WMI Monitor | N/A | N/A |
| 105 | Application Dependency Mapping | No | No |
| 106 | Push Deployment - Add Node | Yes | N/A |
| 107 | Mass Deployment - Push from Web | Yes | N/A |
| 108 | Manual Installation | Yes | N/A |
| 109 | Pull Deployment - wget/curl/etc. | Yes | N/A |
| 110 | Mass Deployment - GPO/MSI | No | N/A |
| 111 | Mass Deployment - Puppet/Chef | Yes | N/A |
| 112 | Deployment via Repository | Yes | N/A |
| Cell | Detail |
| 31: Agent | "Partial" assumes the Orion Server or Additional Polling Engine the node is associated with has routable connectivity to the agent-managed node. The Web Based SSH Client communicates over TCP Port 22 from the Orion Server or APE to the selected node, and does not utilize the agent communications channel. |
