Common NCM Config storage FAQs
Common FAQs on NCM: Where are the configs stored? How long are they stored for? Can you change how long it is stored for? Can we create another copy (as a backup) of the directory in case something happens?
10/10/2018 1:58 PM
10/10/2018 1:58 PM
Common FAQs on NCM:
  • Where are the configs stored?
  • How long are they stored for?
  • Can you change how long it is stored for?
  • Can we create another copy (as a backup) of the directory in case something happens?
Network Configuration Manager
    Configs are stored in the following location: Orion Database > ConfigArchive table.
    Locally in the Orion Server: C:\ProgramData\SolarWinds\NCM\Config-Archive.
    If you will edit 'Default Database and Archive Maintenance Job' (hover your mouse on top of CONFIGS tab > click Jobs), under ADD JOB SPECIFIC DETAILS, you should see the settings on how long configs are stored.
    Yes. Just edit 'Default Database and Archive Maintenance Job' > under ADD JOB SPECIFIC DETAILS and save the changes.
    Manually copy the C:\ProgramData\SolarWinds\NCM\Config-Archive folder on a different location but there is no way to set NCM to download configs on separate folders.
