Collector installation issues
Resolve an issue where you're unable to install SolarWinds Collector.
Unable to install SolarWinds Collector.
The same issue occurs after disabling UAC and restarting the server.
The following error occurs:
The SolarWinds Collector can only be installed on your main or additional poller.
Do the following steps to resolve the issue:
- Backup Windows registry - refer to this Microsoft KB article (© 2018 Microsoft, Inc., available at https://support.microsoft.com/, obtained on Dec 14, 2018) for more information.
- Click Start > Run.
- Type regedit and hit Enter.
- Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolarWinds\Orion\Core.
- Double click Configuration - REG_SZ and set it to FULL.
- Click Ok.
- Try to install the Collector again.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
