Tools
Client does not receive a survey when a ticket is closed
When the ticket status is set to Closed, no surveys are sent to clients. In some cases, surveys are sent but not consistently.
10/18/2018 9:31 PM
4/3/2022 3:13 PM
When the ticket status is set to closed, clients do not receive a survey.  You can manually sent out survey to the clients but the automatic survey is not working.
Web Help Desk
Client email and tech email are the same when testing a closed ticket.
First, select a survey method listed below.
Closed Ticket Email
This method includes a survey invitation link. When you close a ticket, click Save and Email. The client will be able to see the invitation
Survey Reminder Email
This method sends a reminder after a set interval if a survey response is not received from the initial invitation.
  1. Verify that the technician is using "Save & Email" after ticket status is set to Closed.
  2. Go to Setup > Surveys> Options.
  3. Verify that the Default Survey Reminder Interval is set.
  4. Verify if in the Default Setting for Email Recipients if Client is ticked or not (this is if you want to have email updates sent to clients for every ticket updates)
    1. If not, then in the ticket details itself, before closing the ticket and clicking on "Save & Email", make sure the Client is ticked in the Recipients tab of the ticket.
Note that the Survey invitation link is included in the Closed ticket email notification.  There is no separate email sent for the Survey. The customer may have just missed the survey invitation from the closed ticket email.
Make sure that the client's email is not the same email address as the technician's. Web Help Desk will detect that the user is a technician hence it will not send a survey email.
