Clear out the DPE when NCM stuck in Post-Processing
This article describes the issue when the DPE in NCM gets stuck and does not clear out when using it.
- Log in to the Orion server hosting NCM.
- Stop all services on Orion service Manager
- Run Database Manager (Start > All Programs > SolarWinds Orion > Advanced Features > Database Manager).
- Add Default Server
- Run following command to expand (Orion database):
NetPerfMon (default name)
- Right-click on the following table and select Query Table:
DPE_DataProcessorQueue
- Overwrite query with below one:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. TRUNCATE TABLE DPE_DataProcessorQueue
- Click Execute Query.
- Start all Orion services on Orion Service Manager
