Cisco devices display the wrong temperature status in NPM
Current Hardware Health resource is showing correct temperature readings but the status is "major" instead of "normal".
- Open the Orion Web Console.
- Select the affected node in the Manage nodes resource.
- Click Edit node in the Management resource.
- Under Hardware Health Polling for Preferred Cisco MIB, select CISCO-ENTITY-SENSOR-MIB instead of the Global One.
- Click Submit.
Note: This will only be visible if the Hardware Health Sensors are selected in List resources
