Cisco chassis line-card serial numbers not visible in Observability Self-Hosted Hardware Health
In SolarWinds Observability Self-Hosted 2025.4.x, Cisco chassis devices (for example, Catalyst 9400 series) do not display per–line-card serial numbers in the Hardware Health / Hardware Details widgets—even when SNMP polling is successful and the device exposes serials via ENTITY-MIB or the CLI. This is a known product limitation and is being tracked as a feature request for a future Observability Self-Hosted release. Customers can use NCM configuration reports and/or custom SNMP pollers (Device Studio / UnDP) against ENTITY-MIB entPhysicalSerialNum to build serial-number reports until native support is available.
- Symptom / “error message”:
- No explicit error is shown.
- On Cisco chassis devices (for example, C9410R) monitored in SolarWinds Observability Self-Hosted 2025.4.x, the Hardware Health / Hardware Details views show:
- Chassis Service Tag / serial
- Module / slot / PSU / fan health rows
- But no per–line-card serial numbers.
- From the customer’s perspective:
- “We would like the ability to see the serial numbers of line cards on our Cisco chassis in Observability.”
- Customer has valid SNMP/CLI access to the device and can see serial numbers in the device CLI (
show inventory,show module), but not in Observability. - Behavior is consistent across all Cisco chassis nodes; there is no intermittent failure.
- What this article explains (How-to / Problem-Resolution):
- Clarifies that this is a current product limitation / feature request, not an SNMP or configuration issue.
- Lists supported workarounds to obtain and report on chassis line-card serial numbers using NCM and/or custom pollers.
- Provides links to public documentation and THWACK content that demonstrate these workarounds.
- Product limitation / feature gap in Observability Self-Hosted 2025.4.x:
- Hardware Health currently:
- Polls and displays chassis-level information and certain module/FRU health metrics.
- Shows chassis service tag/serial and module status rows.
- It does not surface per–line-card serial numbers from ENTITY-MIB (entPhysicalSerialNum, OID
1.3.6.1.2.1.47.1.1.1.1.11) for Cisco chassis platforms (for example, C9410R).
- This behavior is by design for current 2025.4.x releases and is being tracked as a feature request / roadmap enhancement for a future Observability Self-Hosted release (targeted 2026.2; dates and scope subject to change).
Because this is a limitation of the current Observability Self-Hosted release, there is no setting or hotfix that will make per–line-card serial numbers appear in Hardware Health. Use one of the following workarounds and, optionally, log or upvote a feature request.
1. NCM / CLI-based inventory (recommended, simpler)
Use Network Configuration Manager (NCM) to collect chassis inventory via CLI and build a serial-number report.
Steps (high level):
- Ensure the Cisco chassis node is managed by NCM.
- Configure an NCM command script or job to run on the chassis, for example:
show inventoryshow module
- Use NCM’s reporting capabilities to parse the collected output and build a report that maps:
- Chassis / node
- Slot / module
- Line-card serial number
- Example patterns and a ready-made Cisco hardware serial report are available on THWACK:
- Cisco Hardware report with Serial Numbers (NCM-based report)
- NCM – Add the ability to query for chassis serial numbers on Cisco Nexus devices (feature request + discussion of using entPhysicalSerialNum in reports)
This approach uses standard NCM jobs and reports, and works even when serials are only easily accessible via CLI.
2. Custom pollers on ENTITY-MIB (advanced, SNMP-based)
For environments that prefer SNMP-based reporting, configure custom pollers against ENTITY-MIB entPhysicalSerialNum and build a SWQL/SQL report.
High-level steps:
Identify the OID(s):
- Use ENTITY-MIB
entPhysicalSerialNum(1.3.6.1.2.1.47.1.1.1.1.11) as the primary OID for device and module serial numbers.
- Use ENTITY-MIB
Create custom pollers (Device Studio or UnDP):
- Follow the official “Create custom monitors” documentation for NPM, which explains how to create Device Studio pollers or Universal Device Pollers (UnDP) and assign them to nodes:
- Configure a poller using:
- OID
1.3.6.1.2.1.47.1.1.1.1.11(ENTITY-MIB:entPhysicalSerialNum) - SNMP Get type: typically GetNext for tabular data.
- OID
- Apply the poller to the Cisco chassis nodes.
Use existing examples for serial-number pollers:
- THWACK provides sample custom pollers for Cisco serial numbers, including a ready-made definition for
entPhysicalSerialNum:- Hardware serial numbers of Cisco devices?
Build a report or dashboard:
- After polling is in place and data is collected:
- Use the Report Writer / web report builder or custom SWQL queries to join:
- Node / device identifiers
- Custom poller results (serials)
- Any relevant module/slot metadata
- As a reference, THWACK includes full report examples for serial-number reporting across multiple vendors:
3. Feature request / roadmap tracking (optional, customer-facing)
To have this requirement tracked and prioritized:
- Ask the customer to log or upvote a feature request on THWACK with their use case and case number:
- THWACK Feature Request forum: http://thwack.solarwinds.com/community/feature-request_tht
- Internally, link relevant customer cases to the existing Cisco module/line-card hardware health / serials feature items (for example, Observability Self-Hosted 2026.2 hardware-health enhancement) as per internal process.
