Cisco DHCP device requirements for Orion IPAM
This article provides requirements for adding Cisco DHCP devices to Orion IPAM.
When trying to add Cisco DHCP devices in IPAM, the devices being added must support the following:
1. Cisco Commands that need to be supported:
- ‘show running-config’ - ‘show ip dhcp pool’ - ‘show ip dhcp binding’
2. The device needs to be a Layer 3 Switch or Router.
3. The IOS must be version 12.2(8)T or later.
Note: Enable level 15 is required to view the complete configuration. This is due to how IOS manages permission levels and configuration information.
For ASA devices, the following commands are needed:
-show version -show dhcpd binding -show running-config dhcpd -show dhcpd statistics -show interface l inc Interface laddress -enable level set to enable
For more details see this Cisco article (Copyright © 2019 Cisco Systems Inc, available at https://www.cisco.com, obtained on January 14, 2019).
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
