Cisco 3850 switches display incorrect temperature reading in NPM
This article addresses an issue that causes Cisco 3580 switches to display the incorrect temperature reading in the Orion Web Console.
4/10/2019 2:18 PM
10/25/2022 7:59 PM
While monitoring Cisco 3850 catalyst switches, the temperature displayed in the Orion Web Console does not match the temperature indicated within the device CLI reading.
Orion Platform
  • Known bug in Cisco IOS versions 3.2.0SE
  • Incorrect MIB/OID used to monitor temperature
Perform one of the following procedures:
  • Upgrade the Cisco 3850 switches to the latest firmware.
  • Check the preferred Cisco MIB in global settings. If it is set to CISCO-ENTITY-SENSOR-MIB, change it to CISCO-ENVMOM-MIB.
See the following posts in THWACK for details:
