Check disk usage by top tables in SQL Server Management Studio
This article describes how to use SQL reports to check the SolarWinds top tables by disk usage.
- Open SQL Server Management Studio and connect to the instance hosting the SolarWinds Orion database.
- Right-click on the SolarWinds database.
- Select Reports > Standard Reports > Disk Usage by Top Tables.
